mrmagoo_83
- Aug 8, 2002
Just trying to gather opinions. I am looking for a high output PSU, and after talking people seem to like these two, and a few others, but I like these.
Susquehannock said:I'd choose the OCZ Powerstream over the Enermax personally.
Enermax = 5% load regulation
OCZ Powerstream = 1% load regulation
At this point I should note that the OCZ Modstream is not in the same class as
the Powerstream.
An interesting feat that it may claim. Especially interesting since the units test close to 2% http://www.silentpcreview.com/article173-page4.html and the Topower P6 is not either http://www.dansdata.com/top686p6.htm which the OCZ is based on.Susquehannock said:OCZ Powerstream = 1% load regulation
mrmagoo_83 said:Can you tell me why you would choose the OCZ? I am seeing it has a better amperage per 12V rail which is good.
Spectre said:An interesting feat that it may claim. Especially interesting since the units test close to 2% http://www.silentpcreview.com/article173-page4.html and the Topower P6 is not either http://www.dansdata.com/top686p6.htm which the OCZ is based on.![]()
Susquehannock said:Already knew that. Was quoting the manufacture's specs which can't always be trusted as
you elequantly pointed out. Anyway, 2% is still better than most units is it not?![]()
Seconded. Higher efficiency, lower noise, and comes in the understated look.TSS Modder said:i recommend the Seasonic S12-600. http://www.ewiz.com/detail.php?p=PS-S12-600&c=pw
_Korruption_ said:Seconded. Higher efficiency, lower noise, and comes in the understated look.
QwertyJuan said:wuts your pick ice czar??
QJ
BurntToast said:Seasonic is worse that OCZ or Enermax. That is unless you like the 12v rail to melt to your ATI 9800PRO... TWICE.
Same thing happened to a buddy of mine.
PCP&C 4 LF!
The Powerstreams aren't SLI certified, even the 600W model isn't.xdkimx said:i went with the enermax because at the time it was SLi certified (im not sure if the powerstream is now, probably is)
BurntToast said:Enermax anyday, at least they make their won shit.
OCZ is for the kiddies
The 7800GTX comes in AGP? Because that's what the A8V Deluxe offers.mrmagoo_83 said:Here is what I was looking at:
Asus A8V Deluxe v2.0
2GB Corsair PC3200 ValueRam (Not overclocking so it should work just fine, right?)
7800GTX (was looking at XFX cause they are good & cheap)
DVDR Lite-On
PSU (the question at hand)
AMDx2 4400+ (Too damn expensive right now)
well heres the S12 series (500W & 600W) and their efficiency levels: http://www.silentpcreview.com/article247-page4.htmljonnyGURU said:Not the S12's. They're not as efficient as the SS series. They're also sly about it by saying "up to 80% efficiency" instead of saying "> 70% efficiency" like everyone else. The efficiency of the S12 is actually no better than that of an Enermax.
Which is why I chose Enermax. It's quieter and has better efficiency than OCZ.![]()
Ice Czar said:have a feeling jonnyGURU was suffering from caffine deprivation when he posted that?
the S12's are 80 Plus certified supplies
which has been borne out by independent testing as you so kindly linked.
Ive always found peak efficiency ratings just another deceptive marketing tool
if you happen to be outside the sweet spot for the effciency which more than likely is the majority of the time considering how little power is really drawn unless your constantly folding
which is why I think the S12's are really good as the band of effciency is quite wide and why I really appreciate the way Mike Chin at SPCR puts his effciency tables together
jonny you know something I dont?
(well Im sure you doI mean about the S-12's efficiency)
jonnyGURU said:No. I thought just the SS series was part of the 80plus club.
The S12 430W I reviewed documents "up to 80% efficiency" and I was only able to get 74%@463.5W, 75%@453W and 76%@407W: http://www.slcentral.com/dual-12v-psu-shootout/
Now if that's not true with the 500W and 600W, my apologies for my outburst. I haven't had the pleasure of testing the S12 500 or 600W models.
EFFICIENCY: It's clear that that the efficiency curves of the two samples are not quite the same. The new sample starts a bit lower, catches up at about half power load, then stays at a bit higher efficiency out to max power. The difference could be attributed to the new Japanese aluminum electrolytic capacitors or to increased airflow from the new fan; it is also small enough that sample variance and tolerances within SPCR's testing procedures could be suspected. In any case, it's a negligible difference, especially in actual use. (The actually wattage differences are mostly <5W AC.)
TSS Modder said:o wow. i was expecting much higher values. so gaming w/ a state-of-the-art system will probably reach a max of 350W while gaming...
so i might as well save myself some money and just get the s12-500.... save on heat and power too. awesome. thanks guys! and sorry for taking the thread a little off-topic..![]()
anyways, back to the OCZ vs. Enermax flame war
EDIT: probably not even 350W.... probably not even close![]()
