vanilla_guerilla
- Oct 3, 2005
bought a vendetta 2 because i wanted to see if a could get a few more mhz out of my e8500 e0, since i was using a 92mm hs/f, the xig sd964.
used the bolt-thru kit i had been using with the xig, worked perfectly. well after trying the ocz fan, a high speed scythe slipstream and a coolermaster 110cfm fans in push and pull, it performs about 7c less than the xig at load, about 5c at idle. this is using ceramique in a ll v1000 case with the sides off, ambient around 22c. tried remount, tried stock mounting. so i have seen this ocz very highly rated in a few places. dont bother. these temps seem to be almost as good as the ancient xp90 i have in a terciary system, so back in the box it goes. this is my second attempt to better the xig, first with a tr ultra 120a, which wasnt as good either, but better than the ocz.
