OCZ Rally2 USB drive problem.
czajunia
Wasn't sure if I should have posted it here or in the gadgets section so pls excuse if this isn't the right place.
I just purchased OCZ Rally2 USB pen drive and I think there's something wrong with it. The problem is that the drive's LED stays on all the time. When there's a data transfer it flashes as you would normally expect. I don't know if this is ok but I had two other USB pen drives before and their LEDs stayed off all the time and flashed when there was a data transfer.
Any ideas? Thank's!
the light on my usb drive is always on then flashing during transfer. maybe just a different type of drive? or where the other ones you had the same drive?
No. One of them was Verbatim and the other.... I can't remember. But it wasn't the same. I just found the Verbatim drive, put it in and it does stay off all the time only flashing when transfering files.
What is the size and make of the drive you are using?
I have around 10 different USB drives of various brands and sizes. Some of them have a light that goes on all the time, and some do not. If the drive is working fine with the light on, chances are, it's supposed to be.
Thank's guys. It looks like that's the way it should be with OCZ drives. I was a bit concerned for I thought that it would be the same with all the drives and that's why it didn't seem right to me.
Anyway, it looks like the drive is working properly so just have to get use to it.
Thank's again!
