OCZ Powerstream 600W
Yes it is Alex, but with a caveat. It has two nicely sleaved dedicated lines marked vga-hdd but they are 4pin molex. There is only one 6pin pci-e (also nicely sleeved), forcing you to use adapters. Now, this worked great for my eVGA 6800 Ultra with dual molex connectors and would be fine for a single pci-e card, but I refused to use adapters in my latest setup (partly because of wire management). These are great PSU's of high quality and OCZ support is some of the best out there, and the wattage was fine-very stable with indicators and adjustments. It simply didn't completely fill the bill in this particular rig, and I've gone with a Silverstone 650w Zeus with quad rails and 2x pci-e. Before I did this I contacted OCZ reps to see if matching sleeved adapters could be gotten, or if a modified Powerstream was available: negative on both counts.
alex paik said:
is this psu sli compatible? i only see one vga power plug..
Compatible yeah. SLI certified no. The SLI certified PSU's are:
Antec TPII-550
Antec TP2550EPS12V
Antec TrueControl II 550
Enermax EG701AX Noisetaker 600W
PC Power & Cooling Turbo-Cool® 510 SLI (510ATX-PFC)
PC Power & Cooling Turbo-Cool® 850 SLI (850ETX-PFC)
Seasonic S12-600 Watt
Silverstone ST65ZF 650W
Which doesn't mean others won't work these have just been tested and given the green light.
