Summoner said:PNY Geforce 6800GT @ 420 / 1150
ZenOps said:Allright W1zzard!
If the cables do anything at all, could you dissect one and see if there is some sort or capacitor inside to smooth out voltage ripples or if its just a shielded cable and ferrite of some sort. I'm interested in the technology behind them and if they work as advertised or are just gimmicky.
Bullshit marketting right there in your system, son.Summoner said:Socket 939 Athlon 64 3500+ @ 2.50Ghz
Thermalright 948 w/panaflo H12 92mm fan
2 x 512MB PC4000 Crucial Ballistix @ 500mhz 2.5-3-3-8
lil layzie said:Doesn't the OCZ PowerStream PSU's have these cables on the unit?
I still haven't seen a real review of that psu...lil layzie said:Doesn't the OCZ PowerStream PSU's have these cables on the unit?
joEziLLAH said:Bullshit marketting right there in your system, son.
Summoner said:Special cables arent worth the money, its just BS marketing.
texuspete00 said:OCZ is a good company I'm sure it does something good for your power. Just probably wont make much of a difference. Conclusion - On a high end PSU like there awesome powerstream series I'll certainly take it. Sounds like from this thread you can buy aftermarket cabling Probably not worth it. Especially not as an extender on existing cables.
Don't be so naive brother...just because someone says their cables will do something for you doesn't mean that they will. I would like to see some sites test this stuff out before judgement is made. And if it doesn't make much of a difference at all then what's it good for?texuspete00 said:I'm sure it does something good for your power
texuspete00 said:I think he's picking on you for using DDR rates in your sig. Like 1150 on the GT and DDR500. Makes no difference to me just pointing it out. I do find it funny when people try to PR there own athlons. Some are a bit generous, especially since later xp's were already pretty generously rated. Uhm yeah.... later.
I was saying the difference in resistance between a normal cable and the super happy ultra powerful cable should be so minimal, you won't notice a thing on your multimeter. You finally learned to read between the lines?W1zzard said:current loss? resistance? not noticeable a cable with a certain length has a certain resistance .. no matter what you do .. i will try to measure different resistance is there is any
OK...lopoetve said:OCZ has always been questionable. Their ram has been decent recently, but I haven't seen any REAL reviews on their PSU's, so the jury is still out on them.
joEziLLAH said:OK...
iddqd said:I was saying the difference in resistance between a normal cable and the super happy ultra powerful cable should be so minimal, you won't notice a thing on your multimeter. You finally learned to read between the lines?
OCZ marketing is very happy with your rational thinking.orkan said:more stable voltage = more stable system.
