OCZ PC3200 Platinum LTD Edition
Is there any software about that will tell me what memory Winbond BH-5 or BH6 is being used on my OCZ PC3200 Platinum LTD Edition?
Is anyone using this memory and what sort of voltages and speed is it running at?
I want to overclock it but it seems to want a lot of voltage to overclock.
Did a quick google.... this is from OCZ.
"OCZ Platinum Edition memory modules are rated to handle up to 2.8V without invalidating the OCZ Lifetime Warranty so that performance enthusiasts can tweak their systems without worry."
* This is an end of life product and is no longer available. If you need support for this product, please e-mail support@ocztechnology.com
I also believe they are BH6 IC chips and not the infamous BH5 (but I could be mistaken). All BH5 based sticks I have used in the past (all Mushkin PC-3500s) have been pushed to 3.1v - 3.4v and ran at 2-2-2-5-1T anywhere from 250MHz to 285MHz. I probably could have pushed them further, but had to drop latencies so 285 was as far as I pushed mine.
shoot them some e-mail, I'm sure they can help you determine the exact chips on that RAM... or maybe try searching the OCZ forums.
Good Luck
