OCZ PC-4000 EL vs EB
campey
I'm interested in buying one of these OCZ memory kits.
The EL Platinum XTC: (OCZP5002GXTC-K) 500MHz 3-3-3-8 2x1024MB
The EB Platinum: (OCZ5002048EBPE-K) 500MHz 3-3-2-8 2x1024MB
The odd thing is that the EL (Enhanced Latency) kit has looser specified timings than the EB (Enhanced Bandwidth) kit. Admittedly the EB kit is about 5% more expensive too.
Anyone know anything else useful about the differences between these kits?
Thanks
Campey
The EL will clock a bit higher, but the EB will keep its 3-3-2 timings up to around 260MHz (on average). It just won't go any higher than that.
The EB's use Infineon CE-5 and the XTC use Micron
I run the EB's, I have one of the first sets that came out and they run Great, I can run HTT 270 @ 3-3-2-5 but will go Higher @ 3-3-2-8
It's luck of the Draw like any other IC's on how well it will clock but i dont think you can go wrong with either IC ;)
both are very luck based.. though ocz's 5b F seems to have trouble hitting 270mhz.. so does the CE.. personal opinion? i'm gonna have to recommend the gold line, which uses uccc, until i get hands on experience with the EL's :p
I STRONGLY Second what What Eclipse says, Cause I own A set of PC 4000 Plat XTC & Can't get the buggers past 260 Stable @ all, Avoid them like the Plague, LOL & Ozi, If you were closer, I'd let you borrow & hammer on mine & see what you can get with 'em
:eek:
