OCZ MODXSTREAM 400W PSU pwoering problem
blingbling
Well i bought a new OCZ MODXSTREAM 400W PSU now when i plug it into the wall socket without anything plugged in to check if it works it doesnt turn on!! so i just wanted to know if it will work if nothing is plugged into it will it work like the fan spinning etc etc thnx!
true connecting green to black will cause the power supply to turn on, but sometimes if there is no load on it, like a hard drive or a really large fan, it will just turn back off.
PSUs don't start unless you have something connected to it to tell it to start (i.e. a motherboard). You can fool it in to doing it by shorting two pins on the main 24pin connector - look up a guide.
I don't know why you'd need to do this though?
well i got the psu from abroad so i jus wanted to make sure it will work because if it didnt i cant exchange it!
