OCZ ModStream 520W Power Supply
After looking at the product pictures I noticed that there's only 1 PCI-X cable. Hmmm... looks like I'll have to find something else.
Both of the PSU's you picked are great. PC Power & Cooling being the better one. Here is a review on it if you are interested.
http://www.pureoverclock.com/review.php?id=11
You should know if your case is hot or you actually put a load on it that actually demands a PP&C 510 then it is a little loud. The OCZ Powerstrems are a good alternative that are quieter.
Thanks, looks like Ive decided to go with the PC Pwoer & Cooling.
