OCZ 700W and 4870X2??
craigeric
Would my OCZ 700W GameXStream Power Supply be able to run a 4870X2 card?? I read that this card needs 1 6 pin PCIE connector and 1 8pin PCIE connector, and looking at my Power Supply specs it has 1 6 pin and 1 6+2 pin, am I fine? I really want to get a 4870x2 but I don't have enough to buy a power supply too, thanks for any information!!
_______________________________________
Core 2 Quad Q6600 @ 3.4Ghz
4Gb PC2-6400 Patriot 4-4-4-12 2T
eVGA 8800GT 512mb
500Gb Seagate SATA II hard drive
320Gb Seagate SATA II hard drive
Asus Maximus Formula
Antec 900 Gamer Case
Vista 64bit
Still doesn't answer my question :(
Why did you say "Delete Please"? I just want to know if I am fine, do I need an adaptor and if I do where do I get one? I am sure my power supply's 6 pin and 6+2 pin means I have a 6 pin and an 8 pin right?
That is correct:cool:
The OCZ700GXSSLI? The power is going to be enough, but mine only has 2 6-pin PCI-Express connectors. That is all that is listed in the specs for that model too.
I have mine running 2x HD4850's. Smooth as butter, but maybe if you have a different model than me, you should be fine with the power... just double check the connectors, because for that card you'll need the 8-pin and the 6-pin to feed it.
However, on the ATi website for "Certified" OCZ PSUs only the 800 and 1000 are "Certified" for the 4870x2. http://ati.amd.com/products/certified/powersupplies.html
(I just noticed mine isn't listed for being "Certified" in CrossFireX...)
You should be fine so long as your PSU can actually handle what it's supposedly rated for. I suggest you look up some reviews for that model to make sure. However, your system shouldn't use more than about 450W under load with a 4870X2 if even that, so I doubt you'd have any power issues with your current PSU.
Looking at the OCZ site it says on the left hand side the 700W connectors, so you have the same connectors that I have since we both have the same power supply.(http://www.ocztechnology.com/produc...cz_gamexstream_power_supply-nvidia_sli_ready_)
700W Connectors**:
1 X 20+4-pin ATX
1 X 4+4-pin CPU
1 X 6-pin PCI-E
1 X 6+2-pin PCI-E
6 X Peripheral
2 X Floppy
6 X SATA
So I am almost 100% positive I will be fine, the 4870X2 card needs a 6 pin and an 8 pin PCI-E connector and that's what the specs say that the OCZ700W has (6 pin and 6+2 pin)
No, the one I have does not have the 6+2-pin. I see on the site after 8/15/08 they started shipping the ones with the 6+2, so you're lucky! Not that I need it in my current setup, but it wouldn't have hurt to have either... :rolleyes:
You should be fine sir!
Ahhhh, now it makes sense lol. Well thanks for the replies!! I can't wait to get a 4870x2!!
