Toilet Duck
- May 22, 2005
Hiya,
Earlier, it was suggested that I get a 520w Powerstream from OCZ to power my new comp. I went through with the purchase, but have ran into a "major" dilemma with regards to the DFI nf4 Ultra D motherboard.
The 520w comes with a 24 (20 plus an extra 4 pin) plug, and 2 4 pin (that can combine into 8) plugs. The 2 x 4 that make 8 plugs are blue, while the 20 + 4 are black. If I've confused anyone, let me know.
At any rate, the Ultra-D has 2 main power plugins: a 24 pin ATX, and a 4 pin (presumably 12v) outlet right beside it. Herein lies the problem. The Ultra-D "manual" is rather lacking, and the quickstart guide doesn't even bother trying to tell you where to plug things in. Normally, I'd just throw all of the black plugins in the 24 pin area, and one of the blue 4 pins in the 4pin place next to it. However, the OCZ manual clearly states that, for P4 and Athlon builds, you should remove the black 4 pin connector from the 24 pin setup and replace it with a blue 4 pin.
This has me confused as heck. If anyone's combined this PSU with this motherboard, could you please explain it to me? I have yet to power up the computer out of fear that I've got it backwards and am going to fry it.
One other note.. the PSU comes with a 6pin plug labeled "PCI-Express", but I see no place to plug it into the motherboard... is it necessary or just an extra?
Thanks ahead of time for any advice..
