OC'ing w/ Nvidia System Utility
almostinsane1
I tried doing a little overclocking with the NVSU on a MSI Neo2 Platinum and 3500+ but my PC froze. On reboot none of the USB ports or sound works. I had this same issue with the Gigabyte 939 board and had to RMA it as a reinstall wouldn't fix the problem.
Anyone else experience this?
Unfortunatly, I don't think that utility works well for boards that aren't supported. If I remember correctly there have to be BIOS hooks put in by the manufacturer for the Nvidia utility to work. If this website is correct, it looks like the utility really fell by the wayside: http://www.nvidia.com/object/sysutility_1.08.5.html (supported boards listed below)
Wow, there isn't any Nforce 3 ultra boards listed. You'd think they would have a disclaimer that it will fuck uo your board if you try to use it with an Nforce 3 ultra.
I dont see and NF3 ultra's listed.
So nobody else has had this problem? I find it wierd that I've experienced it twice with different 939 boards.
Sorry I didn't know you meant Ultra. I don't think its a matter of it doesn't work with an "ultra" specific board. Those two listed are probably the only nForce3 boards period that manufactures put the BIOS hooks in for the Nvidia System Utility.
Ya know, all my dumbass had to do was clear the cmos and then my sound and usb came back. But the funny thing is I could OC the board way higher when the sound and usb didn't work.
Go figure.
