I have an Athlon 2600 XP and a DFI LanParty NFII UltraB with XMS 512 pc3200 ram. Ive used the proc for a while doing renders and other such things.
When I first put in the processor the bios defaults had it running at 1.67 ghz, I increased the FSB to 133 and the multiplyer to 14 and got it to 1.87 ghz which was fine while I was rendering and busy.
Now I want to get the proc up to speed and then beyond, but I dont know how much to increase the Vcore voltage to get past
1.87. I left the vcore setting to its default (dont know what that is).
If I increase it too much will it damage the board or the proc? Ive maxed out what I can do with just the multiplyer, if I go past 14 it hangs while looking for the memory and takes a while to clear the cmos to get my old settings back.
Anyway thanks for any help if you can provide it.
