SilverBack
- Jun 14, 2001
I received 2 different 2.8e's this week with slightly different results, both cpu's came from NewEgg. The 1st cpu would run 3.5Ghz with a small increase in voltage to 1.4625v, default for the 2.8's is 1.3875. This cpu would not clock higher at any other setting, higher voltage, loose ram timings etc. It also ran hot! 48C at idle and 55C at load on this water system.
The second cpu which I'm typing on runs 3.5GHz at default voltage, it also runs rock solid at 3.71 GHz but at a very high voltage of 1.61v. This is a no win situation as the motherboard itself became very hot. Hot enough in fact I lowered the cpu in fear of damaging my motherboard.
My assessment of the current Prescott's:
Don't buy one intending to overclock unless you're using advanced cooling techniques. My best recommendation is to wait until the newer 775 pin cpu's arrive and their corresponding motherboards are available. The kinks of the Prescott systems should be ironed out by then.
I will say that the Prescott was a nice addition to my system after the 2.4C
The Rig it's in
The Rig it's in
