as i am an oc newbie (dons flame protection gear) i have some questions after reading the excellent ocing guide..
it talks about ocing from bios, testing for 20mins or so and ocing again. it emphasizes on incremental ocing
what i am curious about is ocing through windows. my mobo(gigabyte) has easy tune 5, which allows me to oc my clockspeed and volt from windows, and i am wondering would it cause instability if i were to oc in windows, find a speed that i am happy with, go to bios and then just set the values that i wanted into bios?
would it then be able to boot or would i have to do it incrementally from bios as well?
cos i already tested out the speed and voltage in ocing from windows.
could the experts point out the flaws ..
second question regarding ocing ram: as far as i am aware, almost all the pros talk about maintaining your ram speed on a 1:1, except for amd. so if i were using intel, would there be any advantage if i were to oc my ram above my fsb?
assume fsb or 200, my current ram is also 200, what kind of advantages if they exist are there for if i were to oc my ram to say 250 or 300 while maintaining my fsb at 200 ?
cos all guides talk about fsb being faster than ram, but i am curious as to what will happen if ram is faster than fsb.. and the advantages it bring
third question: so from the ocing guide, the standard ocing method would be oc, test using superpi, prime95, then oc again.. is that right? or should i add in the doom or ut2007 to test for stability?
i know that sandra is use for benchmarking as well as pcmark, so the stressing tools one should use for testing cpu oc would be prime and super pi right?
also regarding memtest: is there a difference from using memtest in windows and from boot? does it makes a difference in the findins or is there drawback
thanks in advance for answering the quesitons
