CHAoS_NiNJA
- May 26, 2005
Title says it all. I bought a Gigabyte GA-X48-DS4 online used but in perfect shape and started OCing my Q6600. The BIOS was set perfectly and I was already OCed to 3.2GHz without issue and never had a problem. One time, I tried to push it up to 3.4GHz...
Didn't like it, BIOS reset and I lost whatever that guy had done.
Now no matter what, I can NOT get a stable overclock....hell, its getting worse! I loaded "Fail-Safe Defaults" in the BIOS and I still got a BSoD in Prime95...and then again at boot! (The booting issue was fixed by manually relaxing RAM timings) Heat isn't the issue, I don't have the biggest heatsink but it does that job (Scythe Ninja Mini) and I have Everest running on my second monitor to watch temps, When I had it overclocked to 3.6GHz (1.5v) I was touching 65c under prime....high, but not high enough to cause the instability I see acrossed the board.
I used to run 3.2GHz and 3.4GHz on just a hair below 1.4vs (usually 1.35-1.39) but now no matter what I do, I can't get a stable OC.
Halp.
Halp.
