oc'ing program
dig_em
I'm OC'ing my cpu soon and i need a program to help me do it.
CPU: AMD Athlon XP 2200+
Mobo: MSI NForce2 Chipset 400
What should i use to OC?
eheh you don't need any program.
All in the BIOS mate. It would be pretty long to explaine everything ahemmm.
What motherboard do you have exactly? model number
The BIOS is where you apply your overclocking settings. Be carefull though you can damage something or kill someone/yourself changing these settings! If you need any help give me a ring I will be more then happy to help.
Look around for a basic overclocking FAQ that'll explain how to do it in the BIOS.
Ocfaq.com has several good guides.
