ocing noob
Gustavus
holas, Ive got me a A7N8X2.0 mobo
i move my fsb up to 400 (its 166 "external frequency" and i raised it to 200) i think and then when i exit outta setup monitor goes blank and i have to shut down manually then on restart i have to reset cpu speed
does that mean i cant raise it that much??
temps were fine i think, i checked and said 46 C
i dunno what doin wrong, athlon xp 3000+
Well, without knowing what RAM/mobo, settings and timings you're using, I'd say you are pushing it too far.
So what RAM? And did you just push it to 200 off the bat?
uhh im a total noob and dont know exactly, have a dual 512 corsair ram at 7 clocks?? and i did put it there right off bat cuz i didnt kno anytother way to raise it any lower than 200, settings were 100 135 then 166 and 200
any suggestions of what to do aer welcome, should i mess with multiplier?
do you have PC2700 or PC3200 RAM?
Also, your AMD XP 3000+ will not take a 200MHz FSB right from the get go. You have to adjust your CPU ratio accordingly.
find out more about your system and then i can help you more.
Yes, please give us all system specs.
And is that Corsair XMS or just Corsair value RAM? And speed rating? And processor?
Sorry can't really help right now; the information is important and the more you can provide, the more we can provide.
