every chip is different. youll get an answer to the first question when you try it your self. and of course the TT fans would be better if they push more cfms. it just depends on how much noise you want to put up with.Originally posted by Destro
How high would I need to set the voltage to hit 2.2
(for now, maximum 2.4)?
I have a couple of TT smart fans, would it be better
then the Panaflo low rpm?
