I might be ordering my 3500+ today and of course I plan on OCing it. I've been doing a little bit of research and I think I know what I am trying to get at. Here are the components I will be using:
AMD Athlon 64 3500+(duh)
ABIT AV8 rev. 1.1
Kingston PC3200 BH-5 memory with 2-2-2-10 timings
SLK948U w/ Zalman 92mm fan
After all the research I've done I'm still a little confused about the HTT, could someone please elaborate on it? Like if the FSB is 200mhz the HTT is 1000mhz? I heard you set the HTT multiplier so it is a multiple of your memory speed.
If it is a multiplier would a 250mhz FSB with a 4x HTT multiplier instead of the standard 200mhz FSB, 5x HTT be the same?
I plan on trying to get 10x250, would I be able to reach that with my setup? Would I have to set it down to a 800mhz HTT? Or would 11x220 be faster if I have a 1000mhz HTT?
ABIT AV8 rev. 1.1
