OCing 2500+ Mobile in Shuttle
WALoeIII
How far can I push one of these in a shuttle? I'd like to get some decent speeds and I know they run cooler because they have lower wattages. I'm going to go with the Shuttle SN45G.
Should I just skip this idea and go with an NF7-S 2.0 and Antec Lanboy?
You can get a pretty good overclock on the NF7S , I'm not sure about the shuttle but they seem to be decent as far as overclocking goes. And the mobiles OC well anyway.
Thanks for the info. This will be my first AMD system and my first SFF so I want to do it right and OC it :p
well.. i got my 35watt 2200+ mobile today... so i will be putting it in my sn41g2v2.. i will see how high i can get it on the stock fan and without cutting the honeycomb stuff out of the back at first.. then maybe change those things later if i feel the need to.
at any rate, i will be posting my results here, and putting them in my sig also..
also, get a 35 watt mobile... i was dumb and ordered at 2200 before seeing the 2400... but you should get able to get 2.6ghz on a 2400 35 watt barton.. they are $88 at the egg..
One of my friends Oc'ed a regular 2500+ to 3200+ speeds with no prob. in his SFF shuttle. Those heatpipes really work. I might suggest changing the stock 80mm fan in shuttle if the temps are too high. That usually helps and is more convenient than cutting off the wire mesh.
i got mine up and running...
i am at 2ghz.. 166x 12 @ 1.45 (1.424 according to cpu-z) 40 degrees C idle..
i put it up to 180 bus at above voltage and it wouldn't completely load into XP..
the motherboard is supposed to kick up the fan speed at 40 C, but i don't hear it... i might put the fan on max and see if i can get it to run at 35 or something... i also expect a decrease as the artic silver "burns in".. this is only after a few hours...
edit.. i played around with it a lot more last night.. i had it running at 2500 mhz.. i got the fsb up to 210.. even on the igp... also i don't know if my temps are right or not because i can't tell if mbm is set right, i think the cpu and case temps might be switched.. i think right now i got it sitting at 200 x 12 @ 1.65v and i will leave it like that all day... it was at 166 x 14 i think, all night long with "smart fan" on.. and i kept hearing the fan speed up for a second and then slow back down... and it sounded almost like a dying fan...
