OC'ed Problems... Nf4/Asus/SLI
Synikal
Ok so, here is my deal. I have been playing with just the FSB because everything seems really technical and has changed allot since Nforce1 board ;)
Here are the system details quickly before I continue…
(ALL ARE RETAIL PARTS NO OEM)
CPU- A64bit 3000+ Venice / @1980hmz (x 9.0 & HTT @ 220 )
CPU Cooler - Gigabyte Cooler-PRO PCU21-VG
Motherboard - Asus A8N-SLI (non delux) Rev A3 Bios 1006
Ram slot 1 - Corsair: CMX512-3200c2 - 3.0/3/3/8 @ 220Mhz ( 1GB total )
Ram slot 3 - Corsair: CMX512-3200c2 - 3.0/3/3/8 @ 220Mhz ( Dual Channel )
(SPECS) Cas Latency - 2 / Timing 2-3-3-6 / ECC - No
Video 1 - Asus Geforce n6600GT - in SLI
Video 2 - Asus Geforce n6600GT
NON RAID DRIVES
HD1 - Western Digital Caviar SE WD800JD 80GB 7200 RPM Serial ATA150 (Sata plug 3)
HD2 - Western Digital Caviar SE WD800JD 80GB 7200 RPM Serial ATA150(Sata plug 4)
What I'm trying to achieve is an Over-Clock that will finally make me proud of my new machine. I have been struggling now for almost 3 months, trying to get this thing to rock my socks... I need to know exactly, how to do this. I have never been able to go above my current clock settings. Could anyone share some setup ideas for me to set my system to open this beast up? I hope I have provided enough information for the HardTroops.
Have you tried bumping the voltages (Vcore and memory) as you go up?
I'd highly recommend you update that bios too. I'm using the sameboard and bios 1011.2 is more stable then yours for sure.
Well i just thought of somthing... lol Lowring my HTT to 3x... put CPU to 1.51v @ ram @ 2.7 T1 3,3,3,8 but i think ram is only running at 150 mhz...
