I had a CM GeminII sink with 2 120x20mm Antec tricools on my E4300 at 3.3Ghz at 1.48 max vcore (the board setting is 1.5, actual output is 20mV less on average on my MSI P35 Platinum) I was getting 80C temps with the board open on a box.
I have a 4850 with the Accelero S1 V2 with its own 120mm fan and the northbridge has a Crystal Orb since the board did not come with the heatpipe multichipset cooler. I have zalman ramsinks on the power circuitry adjacent to the cpu socket at the back of the board.
I bought this vendetta 2 cooler a little while ago and some Noctua NT-H1 paste to replace the Arctic Silver Ceramique that I have been using. I totally cleaned the cpu with the 2 part ArcticClean solution and applied the paste using the small bead in the IHS center smoothed and thinned with a plastic card until it covered the IHS..
Now, I had to boost the voltage a touch again to get a max Vcore of 1.512. Now the temperatures oscillate between 70C and 83C, again with an open board. The room temperature is 30C and the idle temp is 46C on the cpu.
All voltages were read with CPU-Z 1.46. All temperatures were read with Speedfan 4.34.
All high temperatures were obtained with Orthos Beta running the Blend option. The second boost in voltage was to get past even one loop on Orthos, currently at 22min as I write from the machine in question.
So, are these temperatures not surprising given the applied voltage? Should I back off the OC due to this temp, as putting it in the case will likely boost the idle temp and thus the load temp?
