Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Bumpity :/ can't really figure it out...I'm considering clocking back down to 11x185 and verifying that the overclock is the cause, and not something else.
mines the same- the ram cant quite handle 200fsb properly so it runs better at 196. What speed ram are you using? maybe its getting errors so its having to resend information to sort it out- therefore slowing you down. Run prime 95 to make sure your system is stable at those speeds
