no, not really. some 6800 series cards have been crapping out from OC's and voltage increases...Fistandantilis said:is that the same philosophy for GPU's?
when that mod was first discovered, i did it too, then a few weeks/months later, people were reporting that their cards were taking a crap and not working anymore, even at stock volts/speeds. its good taht you have tha tpower regulater activly cooled though.ryuji said:never hered of 6800s crapping out, i got mine at 1.4v, and i have the (it got real hot) voltage regulator actively cooled, think i have a problem? oh yea the core temp neveer goes above 48C
maybe the regulator burnt up, the sink got hot enough that it was verry close to burning melithium726 said:when that mod was first discovered, i did it too, then a few weeks/months later, people were reporting that their cards were taking a crap and not working anymore, even at stock volts/speeds. its good taht you have tha tpower regulater activly cooled though.
