To my understanding you want a stable system with the lowest possible core voltage correct?
I ask because I will be OCing my 2500K to around 4.5 with a starting voltage of 1.35. Should I go up from there and see how much higher I can comfortably go, or should I test stability after dropping the voltage? I'm not looking to push my cpu to it's limits. I want a basic OC in combination with longevity.
Will be using UEFI btw.
