Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
is it a r350 or r360 core? some programs lie about it, to find out you might have to look at the core itsself. r350 = 9800pro, r360 = 9800xt in disguise.
The stock heatsink is pretty weak. You might not get a very good overclock using it and most certain the core will be pretty hot if you do overclock using it.
shim removal ins't adviceable... Shim really protects the weak ati core well.
Ive chosen to mill/file the edged of the coler... Now the ati core has direct contact with the cooler plus the shim is microts away from the cooler There to catch any bad forces!
