First, this is my first time OC a cpu. I OC the e8200 to 3.0ghz and the two ram together went to 900mhz. Here is a screenshot of the cpuz . To overclock, I only need to bus speed and voltage? Should I link the memory and bus speed together or separate it? How would I know what voltage is good for the cpu? Is 44c-47c temperature for the cpu good?
Thank you
Thank you
