Alrighty,
I plan on using the Asus P5Q-Pro as the motherboard and will be buying the Q9550 as the processor with the XIGMATEK HDT-S1283 with retention bracket as the cooler. I already purchased the Antec P182 for my case and have the Corsair 750TX as the PSU. I have also upgraded the case fans to the Yate Loon's.
Question is:
Will it be likely that I will can OC the Q9550 above 400 Mhz on air (Assuming I bought the ddr2 800) Or, will I be able to hit somewhere between 400 and 533 Mhz with 1066?
I understand the Q9550 runs a little warmer that the C2D, I just want to make an informed decision on my memory purchase.
Thanks.
Question is:
Thanks.
