Turn on Orthos, run small FFT's for a few sec, my ABIT IP35 Pro will then spin up its fans and then orthos will turn red and say "STOPPED". My motherboard will then beep every few seconds until I turn off orthos. Prime95 also seems to not like to have a second instance open (btw, where can I get prime95 with those worker threads? I have to open a second window).
"Type: Small FFTs - stress CPU Min: 8 Max: 64 InPlace: Yes Mem: 8 Time: 15
CPU: 3200MHz FSB: 400MHz [400MHz x 8.0 est.]
2/5/2008 5 19
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1
ress Stop to end this test.
2
1:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:FATAL ERROR: Rounding was 0.5, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 0 minutes 4 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 0 minutes 4 seconds - 0 errors, 0 warnings.
1:Execution halted."
EDIT: I have no problem doing anything else. Play TF2 for hours no problem, installed some adobe and MS apps no problem. Browse internet, listen to music np...
2/5/2008 5 19
1:Using CPU #0
2:Using CPU #1
1
2
2:Execution halted.
