OC-Not Prime Stable-3Dmark06 OK
  • Thread starter Deleted member 143938
  • Start date
D
Guest
My new OC doesn't pass blend Prime test, fails after ~1-2 hours, but I game fine and 3Dmark06 passes, is this something I should be worried about? Taking into concideration it's a CPU problem, because RAM passes memtest.
You should be ok. I've been trying for days trying to get my opty stable for prime blend on both cores. One keeps failing. It's 16 meg pi stable, and passes 3dmark06. The only thing it doesn't like is prime.
I think you'll be fine, you just won't be verified as a stable overclock. It just depends on who you ask I guess.
just lower the clock down 50MHz. If it is unstable, it is unstable. You don't know when it is gonna happen, and Murphy's law says it will probably be at the worst time possible.
honestly... i know the frustration I am still working on getting my OC to stick for longer than 3hrs in prime... but you need to get it to. expecially if you write any school papers on it or anything important. But yeah... either up your vcore, lower your mhz or get better cooling...
or mes with you ram divider/timings... sometimes its the mem controller..
also i dont call it stable until it can do prime 12+ and run 3dmark with prime running for atleast 2 hours..
