ThePerformer
- Jun 9, 2003
So I've been trying to stabilize my rig for a few days. Here's the situation:
I had it OCed to 2.8 (multiplier was 8x instead of 9x) and it seemed great. Except that my memory multiplier was much lower than the rated 1142MHz for my RAM. I was running CAS 4 at 800MHz but I wanted to up my memory speed.
So I switched to 5:4 and tweaked it to around 1142 and gave it 2.2V. I switched the CAS back to the rated 5.
So guess what? The system was unstable.
So I turned down the OC. Processor was now around 2.7GHz and the memory was around 1100MHz with 2.2V. The processor was getting 1.44V or so btw.
Unstable. Would crash during games.
So I keep turning it down. I can't find any stable area where my memory is above 800MHz EXCEPT when the processor is only at the rated 2.4GHz. Then the memory will run at 5:4 at around 1100MHz now.
So here's the deal:
-System is unstable when CPU is OCed and memory is above 800MHz but stable when at 800MHz (waaay under its rated speed)
-System is unstable when CPU is mildly OCed (2.5GHz even) and memory is at rated speed but stable when at CPU is at 2.4GHz and memory is at 1100MHz
So, normally it's pretty easy to tell if the CPU or the memory is what's unstable. But this is driving me nuts!! I can't figure out which one I need to turn up or down!
I got the system ALMOST stable at like 2.8GHz with 1100MHz. It would stay up for about an hour and then go down reliably. However, when I turned it down just a little bit, the symptom remained until the CPU was back to 2.4GHz.
I'm so confused. Help me guys! Thanks!
So here's the deal:
