oc help with DFI
mattk
ok guys i got this new system in my sig, and i am overwhelmed with all the overclocking features on this motherboard..for any of you that have had great success overclocking, can you please give me some tips for this board? i don't know what half of this stuff means. Thanks
you're right, there are a crapload of options.
what specifically would you like to know?
well i don't really know much about overclocking the ram, this is my first board that even lets you adjust all these different timings. I understand that your processor cannot run at a higher speed when you have really low latencies on the ram, but say i wanted to oc it from 2.0 to 2.5 ghz, what do i have to do with the ram? the fsb would be 250, the ram freq? the cas latency would definately have to be atleast 3 i imagine, but im sure these 2 things aren't all i need to change for this much of an overclock to work.
you can change the ratio between the RAM speed and the HTT speed, so that you aren't limited by your ram.
lets say at default, you have your RAM @ 200MHz, and your HTT @ 200MHz.
if you up the HTT, you are also upping the RAM.
under DRAM Config in the BIOS, you can change the ratio.
for a 2.5GHz core clock (with DDR3200 RAM):
you would change the RAM (under DRAM Config) to 150MHz
and change the FSB Frequency (HTT) to 250MHz
that would give you an effective RAM speed of 200MHz
and a core clock speed of 2.5GHz
