Apr 8, 2007 #1 S skull@ n00b Joined Mar 24, 2007 Messages 39 My bios defaults gives me this: I know somethings wrong. I would like to look like this: Anyone can tell me what to set to what in the bios so I can get this? Best regards, Skull@
Apr 8, 2007 #2 S skull@ n00b Joined Mar 24, 2007 Messages 39 When I start CPUZ right after boot (still booting) the speed(and the voltage) start changing, at some poings... can vista be doing this?
Apr 8, 2007 #3 L loft Limp Gawd Joined Jun 10, 2004 Messages 258 Nope. If you haven't already, disable EIST (Speed Step) and C1E in your bios. Depending on the motherboard, should correct this issue.
Apr 9, 2007 #4 J Jon8RFC Weaksauce Joined Aug 5, 2004 Messages 83 I know you're running a desktop, but my only option on my Dell laptop (next to zero bios options) was to go into the power properties and set it to "always on": http://jon8rfc.homeip.net/other/power_properties.png And it doesn't throttle anymore.
