OC Help, Computer restartings..
DFI INFINITY NFORCE2 ULTRA400 SOCKETA DUAL DDR AGP 5PCI SATA SOUND LAN 1394 MOTHERBOARD, AMD MOBILE ATHLON XP-M 2500+ 1.86GHz 266FSB BARTON 45W 1.45V OEM, x2 OCZ 512MB PC3200 DDR400 CAS2 3-3-6 184PIN W/ COPPER HEAT SPREADER
Sorry about the caps, but I just copied it from a site that way.. That is a list of the important internals in my computer, and I have a thermalright heatsink... I'm new to OCing, but the problem I'm experiencing is my computer starts up fine, runs at a temperature of 30-31 degrees when OC'd to 2.4ghz with the multiplier on 12 the FSB at 200mhz, and the vcore at 1.75. Whenever I try to open a program other than msn, or my internet browser, my computer just restarts.. I converted everything back to normal settings in the bios, and I seem to be experiencing the same problem. I'm wondering if anyone can run me through a complete check of what I should revert my bios settings to, or give me instructions on how to fix the problem. If you could add me on msn, carbonoxide33@hotmail.com or something, and walk me through some things, or reply here it'd be greatly appreciated.
(help)
wow whats ur hs? my alx 800 with 3000rpm gives my xpm 2500 @ 2.4 ghz does 39c idle at 1.600vcore. damn, ur vcore is 0.15v higher :eek:
