OC fresh meat... help me out
Allrighty then. Just built new computer. E6600, evga 680i, Zalman 9500, 2 GB Corsair Dominator DDR2 800, evga 8800 gts 640, Corsair 620HX
I want to overclock but have not done much in a few years.
So far i've disabled cpu thermal control, c1e, Intel speedstep, and all of the spread spectrums.
Not really sure on what I should do next, and how much I should do...
Should I lower the multiplier first, or start bumping up the FSB, or all at once? How much of a jump?
Updates: I cranked up the FSB to 270 Mhz (qdr 1080). (core speed is now 2.43Ghz) Temps are not getting above 48c on full load.
QDR now at 1090. Temps still the same.
UPDATE: Did some more research. boy, I'm barley getting my toes wet. Cranked up the CPU Core to 1.45 volts, CPU FSB to 1.5v, and the nforse SSP to 1.5v.
brought QDR FSB to 1104, booted into windows... going to continue cranking up the QDR FSB....
Got it running at 2.93 Ghz! (I know, not that impressive., but I'm having fun and learning too!)
I'm going to hold off here for a while, and check for stability and temps. running 2 instances of Orthos at the moment. Temp hasn't gone above 43c
Is this good/smart/stupid so far?? Am I being too cautions?
