Hi all
I am currently running my x2 at a modest 100Mhz OC at 2.3GHz. Because I have 4 x 512MB ram modules, I can not run the ram at full DDR400 speed so it is running at DDR354 right now.
I am considering replacing this ram with 2 x 1GB sticks, so that I can run it at full 400 speeds, but if I do this I might have to put my CPU back to stock speeds - unless I can overclock the ram a bit. Assuming that I CAN'T OC the ram, will I still see any increase in performance going from 350-400MHz on the ram, but losing 100MHz on the CPU???
The RAM I would be getting is OCZ EL PC-3200 Platinum CL 2-3-2-5 in 2x1GB Modules.
