OC Conroe Mem Divider Question
cditty
On a P5W DH, I have my FSB set to 333 for 1333. I am running my DDR800 at DDR666. Is that the correct divider to use or should I try a higher one? I think at 666 I could probably tighten the timings a little bit.
What do you guys think?
im using the gigabyte ds3 and using 1:1 ram divider i hit a wall at 330 fsb on a E6400.
i changed the divider to 4:5 and currently priming at 365fsb.
You can find out your FSB to the max and then set it later to max your ram bandwidth as the egample given above me.
