Optimummind
- Feb 11, 2004
Since my 9800Pro can overclock easily to 445MHZ for the core and 365MHz for the RAM, I decided to extract the originla BIOS file from my card, change the default core and RAM clock speeds to 440MHZ and 360MHZ, and run the card this way.
This way, I don't have to depend on OC'ing utilities like Radclock or Powerstrip.
I noticed in Radedit some additional options like setting the BIOS to initilize using CAS1, CAS2, and CAS3 type memory settings.
I was wondering, has anyone in here changed the default CAS setting for his GPU's RAM and seen better results?
If anyone has set the RAM type to CAS1, did you have to underclock the RAM's speed from its stock speed to make the card stable?
