I bought a Palit 8800gt 512mb a couple of weeks ago and was finaly able to try to overclock it with the VDO tool that came with it. The defaults are set at: core clock 600 mhz, memory clock 900 x 2 mhz, and shader clock 1500 mhz. I used Oblivion as a test game, set to full eye candy except for the shadows (shadows in games bug me, they were all turned off). Working up one at a time I was able to get it to play stable for an hour with the core clock at 700mhz, and then the memory clock at 990 mhz, then both for an hour.
There is a box marked "link clocks". With the box checked it raises the shader clock to 1750 mhz. I was able to play with out any glitches for 2 hours with these settings. I set the fan to 100% and the gpu temp stayed at 59c
Ok now my question. What should I do about the shader clock? Just leave it as is being linked? Or should I set the others back to default and see how high I get the shaders? This is my first real try at ocing, so any workable suggestions would be appriciated.
