OC 3570K 4200mhz
Rikus78
Hellow I have this pc:
Chase: Antec Nine Hundred
Power: Corsair TX 650 V2
M. board: Asus P8Z77-V LE
CPU: 3570K
Working at 4.100 Hardware Info shows a vid of 1,24 and Hardware Monitor 1,14v. So the only thing i touch in bios is Offset negative and 0,050. After hours of Prime 95 works fine no problem.
For 4.200 mhz i use same config, but after 3 minutes of Prime shows a blue screen and reset.
I tried offset 0,040 but still the same.
I think the problem is not the voltage, maybe it´s time to touch LLC and other parameters i don´t know?
CAn you tell me what parameters to change please for 4.200 mhz?
Greetings
All I did to clock mine to 4.2 was to increase the multipliers on the turbo to 42. Left everything else alone. I'm told you can go to 4.4mhz just on the multipliers.
A negative offset is actually reducing voltage below stock/default voltage. So you're going to have to keep bumping the voltage up (moving towards zero in your case) until it's stable.
Why lower the voltage?
Set it at default and you should be fine at 4.2ghz, might need to increase it actually.
So for 4.200 i don´t have to touch LLC and other parameters? only voltage?
Greetings
Stable at 4200 with offset negative 0,030
I don´t touch anything else like LLC or PLL
Greetings
Mine won' t boot below neg 30. Also prime is crap run occt or intel burn test
