Arcygenical
- Jun 10, 2005
To all you lucky Obsidian 800D owners out there - I have two questions for you
1. There's a considerable gap between the top of the motherboard and the top of the case - most likely designed to accommodate a nice WC radiator and fan setup. I am wondering, however, if there is enough room up top to hold a PSU - provided the back of the case is modded to accommodate airflow. IE I'd be looking to use the entire bottom compartment for something else (Stacked radiator and a Pico-ITX system), and would need to put the main PSU up top, in that vented portion. I am aware it would block one of the 120mm top fan slots.
2. Just how much space (height) IS there in that bottom PSU compartment. From the bottom of the case, to the bottom of the case subfloor - how many inches do I have to work with (for stacked radiators).
Cheers everyone - Any information on this would be GREATLY appreciated!
