Obsession with having the IO plate
I see this a lot in the fs/ft forums about people specifying they have it or they must have it in a what to buy thread. For me they go right in the trash after I open the box.
I personally hate them back in the early days of pc building I cut myself a few times trying to put them in. They restrict airflow slightly, and serve no real purpose.
Who honestly spends time or has their pc displayed in a way that shows the back of the pc? How often does a person actually look at that anyways?
Just wondering why so many people care about these.
its about the details for me, as well as it does stop dust from getting in :)
I will offer my 2 cents...
Mainly since when I build my computers I am anal about every aspect. I cannot stand a computer that isn't 100%. The I/O shields are beneficial for the grounding of the back panel connectors, granted it may not be that big of a deal, but still good to have.
I think they offer a cleaner look too... I mean, who wants to see a gaping hole in the back of their computer?
I will venture a bet most of the people on the forum use and like the I/O shields, for various reasons of course, but I just personally prefer them.
EDIT: Also they'll help the re-sale value too. Many buyers want that shield with the board, I know I would.
It keeps a little dust, snakes and mice out of your computer. Also it is an EMI shield that is required for the FCC inference certification of the board.
just looks nicer, stops people from plugging things in and missing if building for someone else.
I agree with this...Im the same way.
I want to I/O shield with every board I buy.
I always have to have the IO shield as well. I picked up a board from a friend who could never find the IO shield. Ended up costing about $10 from ASUS but it was worth it. Just does not feel complete with it missing.
I'm pretty sure the I/O plate actually helps airflow when fans are set up right. It make it easier to direct the airflow where you want it and not have it just flowing out a gaping hole in the back of the case.
Since i paid $350 for my case, I'm not gonna put a motherboard in it without an IO plate.. on my old system.. I didnt give a shit, it was a $60 case.
I don't buy that at all, any setup I can think of it's allowing more heat to escape
I can understand your opinions on wanting it, but seriously you would not buy a motherboard for not having it you were considering?
no cschill you're right, leaving the IO plate off would screw up airflow in a properly oriented fan setup inside an otherwise sealed case. airflow is disrupted if you let air seep in/out holes and cracks, it can even create dead spots...and come on, i mean who wants dust bunnies, animal fur or whatever getting sucked inside their case?? no thanks
no cschill you're right, leaving the IO plate off would screw up airflow in a properly oriented fan setup inside an otherwise sealed case. airflow is disrupted if you let air seep out holes and cracks, it can even create dead spots...and come on, i mean who wants dust bunnies, animal fur or whatever getting sucked inside their case?? no thanks
I would love to see a test that proves this. I think it's complete bs. Airflow doesn't work in this nice idea of a wind tunnel like so many seem to think, especially with a computer that has a cpu and video card heatsink.
As far as dust bunnies go, air should be exiting from there anyways the only issue I have with that is always where a fan's intake is.
I bought a mobo that didnt have one and had to check asus website every day to get one when it was finally in stock. I had to get a slightly different one so there is an extra hole for something I dont have but I didnt want things to get into my case so i needed something there.
The only instance I can see it helping air flow is if you have the CPU fan pointed at the back hole so the hot air was blowing out there.
Yeah, wouldn't buy a mobo without it. Unless the motherboard was a damn good bargain, and I could pick one up from the OEM. Without it, your case isn't complete, isn't perfect. :) I'm a perfectionist, and it just seems 'ghetto' to not have it :p
Someone call the Mythbusters!
I agree with this. How much does it really effect it though? I have no idea.... it would depend on the setup.
If the cooling of a case relies on a slightly positive pressure inside the case, then that could certainly muck things up a little, however not nearly enough to notice :p
I prefer them, personally, but if I found a good deal on a mobo that didn't have one, I wouldn't really care
Back in the days of Beige PC cases, with little to no ventilation holes, it was sometimes worthwhile to pop off the backplate if the PC got too hot. These days though, cases have super ventilation all over the joint :p
I'm pretty sure this is just a case of "I don't really care if the things I buy look like shit or not as long as they function." Some people do... I'm sorry you don't.
Oh, don't get me wrong...I'm not saying it's a deal killer for me. My last setup didn't have the I/O plate for the 2 years I had it. Just kinda playing devil's advocate here. There are legitimate reasons for having the I/o plate, but it's also a matter of personal opinion. Pretty much it comes down to; "it's your system, do you care if it's there or not".
lol no I like everyone else like things to look good in my house. The back of the pc is not on display to anyone except me when I'm plugging something in, and then I don't see it again usually for months. I think they look better without it anyways. It just boggles my mind that this would be a deal breaker for someone buying a mobo.
My EVGA Classified came with an awesome looking IO plate that has cushioning on it, makes it a bit harder to fit in, but it looks really nice. So I think it just looks kind of half done if you don't put in the IO plate and then you look at the rear of the computer.
I build and resell computers on craigslist.
Not an easy sell when customers notice there is no I/O panel even if they are total noobs.
Sorta like selling a car with no front grill. Yea the car is still 100% perfectly fine but it still raises a brow when your trying to sell to someone.
Really cause I've sold well over 20 pc's on craigslist and it's never came up once. Also it's nothing like selling a car without a front grill.
it's more like selling a car that's missing an engine cover. you're never gonna see it unless you pop the hood.
we need a poll
i/o plate all the way. i dont want a big hole in the back of my computer where dust can accumulate. plus u can feel around easier to find a port without worrying about sticking your finger into something you aren't supposed to.
The thing is if you have an exhaust fan near your I/O Shield, its possible for the fan to grab some of it's air from the hole around your motherboard - Instead of the front of your case where the coldest air is located.
I personally prefer to have an I/O plate with every motherboard I purchase; new or in the FS/FT section.
If a motherboard I want doesn't come with a I/O plate then I'll look to see if I can purchase one before entering into an agreement with the seller of said motherboard.
The only variance from this is if the motherboard is going to be used as a test bench for various components. Then I'll accept the board without an I/O plate.
Because I don't want to be trying to stick a USB port in the back of the motherboard and short out something in the process.
It's ironic you mention this. I was talking to Cschill the other day about this very same issue, when I took my side case off, to see what it did to the temperature. It actually was counter productive. Think of it this way. You're going to feel more air on you if you are in a hallway with a fan blowing on you, than you are if the fan is sitting in the middle of an open field.
The I/O plate serves as a little extra support for the connections on the motherboard, especially if you use onboard VGA, serial, or parallel ports.
It is a lot harder to rip the connectors off the board when the I/O plate is there.... yes, I have seen a board that somebody ripped the VGA connector clean off. It woudn't have happened if the I/O plate was there.
I assume you have fans on the side of your case, like most of us do...
Meh. I'll use it if I have it for the same reasons people pointed out. But I'm not going to lose sleep over it if I lose it or buy a mobo without one. But then again, I don't care if I take an odd number of footsteps to my car in the morning, and I don't care if all the pencils on my desk are all in a perfect line. :D
While the I/O shield isn't something typically seen due to it's location it is quite simply an incorrect installation of the product. It is meant to be there. It is included with the Motherboard. To me it looks like a hack job if it isn't put in place.
Still using a 15-year old full tower case converted from AT to ATX, part of which was carving out the area in the back for the I/O riser.....Of course, it was far from a perfect job, more like a hack job in fact, and it's large enough for the ports to fit through, but not for the panel, and it needs to be evened with a dremel anyway. So, until I get around to that, no I/O shield for me. But if I did, I would be sure to put it on!
