Observations on AGP Voltage.
edit_text
My IC7 has a default AGP Voltage of 1.55. With ATITool I determined my MAX overclock on my 9800np. Sadly, my mem toped at ~315. I'm thinking, "OK, lets just try the AGP voltage. Can't hurt." At this point, (AGP @ 1.6v) my mem can't even hit 300... That leaves only one thing to do. After setting the vAGP to 1.5 I find my card to me stable at ~320. Not a huge increase, but it certainly didn't hurt.
To recap:
@1.55 - 315
@1.6 - less than 300 (stock is 290)
@1.5 - 320
Has anyone else seen similar results?
e_t
edit: It should be noted I did not test to see if the core overclock was affected.
To recap:
@1.55 - 315
@1.5 - 320
e_t
Higher voltages means more heat so that seems quite normal. Especially if you got no heatsinks for the RAM.
That is also my thought. I was going to volt mod my card this weekend. If the temp is already a problem, I don't see how a v-mod will help. However, I was under the impression that vAGP didn't really matter because the card has it's own voltage regulations. (I know, why did I bother it in the first place then.) I'm gonna probe it a little tonight with my multimeter to see how much affect vAGP has on the the cards voltages.
e_t
I've compared the ram voltage at a few diffrent vAGP values:
1.5 - 2.78
1.55 - 2.78
1.6 - 2.78
So, how is it that my ram can OC further at 1.5, but at 1.6 it can hardly run a stock. So now, my top end is 410/315. (This is after backing off just a bit) Not a huge increase over the 400/310 I was getting at vAGP of 1.55 but a clear diffrence. Odd.
e_t
