oblivion x1900xt
Matt Samoohi
i have an x1900xt and the the drivers which i have swicthed around from diff versions 6.6 6.8 ect.. and whenever i go to oblivion i cant enable hdr+AA it wont let me it says it cant be enabled what should i do? Also i have an abit at8 32x motherboard and are having trouble with my gskill pc4000 2gb set i really dont know if its using the full ddr500 and my opty 170 cant go pass 2.4 ghz when trying to boot up. I dont know how to swicth around setting because in the abit bios i only see uguru . Also when i use ddr500 setting in the bios it reboots with a black screen and all fan speed are up and no signal it fried my last mobo and this time i have to reset the bios using a soft cmos. AND MY LAST problem everytime i boot up it dosent deterct my 500gb hd and i turn it off and boot up again and it detects it also its detected as an ata 33 even thought im using a sata 2 cable because i used an ide as a secondary b4 from my old dell too move data around.. WITH all thnese problems i regret building my first pc its been 2monthes already
inZane said:
You have to download the "Chuck Patch" to do that.
Yes. you need the chuck patch, but even then you enable AA in CCC and not the game.
i used the chuck pacth no go so tae should i disable aa in oblicvion and just enable it in ccc
The 6.10 Beta (and all official drivers after) have the "chuck drivers" integrated.
