Brent_Justice said:Working on a review right now with an X1800 XT in it, and Oblivion.
Good. Now do one with an x850xt and a 7600gtBrent_Justice said:Working on a review right now with an X1800 XT in it, and Oblivion.
Help a brotha out!Brent_Justice said:7600 GT will be coming, basically Oblivion will be included in our lineup from here on out. I love this game![]()
I didn't say it did.texuspete00 said:x800 does not support the type of HDR Oblivion uses pxc.
B ecause you don't have a card that's not yrt inventedAppaYipYip said:Someone tell me why I cannot turn on HDR AND Anti-aliasing at the same time?!?!
Lies.Hartz said:You can turn on AA with CCC on ati cards and that leaves it on even if your have HDR.
bLaCktIGErs91 said:B ecause you don't have a card that's not yrt invented
It's a hardware impossiblity, on ANY card![]()
That's my point, it's not possible ATM, with oblivion, as he askedLazy_Moron said:That is false. ATI X1800 and X1900 series can do any HDR with AA. It has to be in the code though. Oblivion doesnt have it in the code. I wouldnt doubt though that it will be added. The game been in development for 4+ years and back then HDR and AA was impossible and they probably didnt think anything of it. Then ATI comes out with the X1800 series and X1900 series and now its possible. But they dont have it in the code. I wouldnt doubt see it in a patch or two for HDR and AA to work together on ATI cards.
bLaCktIGErs91 said:That's my point, it's not possible ATM, with oblivion, as he asked![]()
Sorry I spoke to soon.bLaCktIGErs91 said:Lies.
I was referring to the nV cards hes running onTrimlock said:if "ANY card," excludes the X1K series from ATI, then yea i guess it is impossible
The problem is the framebuffer format bethesda used. No current PC video card, including ATI X1xxx cards, supports AA in that mode. There will not be a patch "soon" to enable AA+HDR on the PC. Bethedsa has never mentioned making one, but has often repeated that AA+HDR is not possible on the PC on the official boards.Trimlock said:there will be a patch for the PC soon (rumor so take it how ever you want it) that will allow you to enable AA with HDR on.
Generalizations are bad, m-kay? http://www.beyond3d.com/forum/showpost.php?p=716900&postcount=40 Some HDR modes support AA and some don't.Lazy_Moron said:That is false. ATI X1800 and X1900 series can do any HDR with AA. It has to be in the code though. Oblivion doesnt have it in the code. I wouldnt doubt though that it will be added.
Bona Fide said:I don't believe that...the X1900XTX/7900GTX are limited to 1280x1024?![]()
ryankenn said:My 7900GT is running it with HDR at 1280x1024 with no problems ( HQ ), so I should expect they can do a little better.
1280x1024??? Why when using a high end card
Sharky974 said:people run nowdays is 1280X1024 on LCD's.
