Lord_Exodia
- Sep 29, 2005
OMG!!! this new oblivion patch is amazing. Everyone I recomend you get and install this patch. ALL of my 7900GTX problems are gone. No more odd slowdown then speed up problems. The game hasn't crashed or frozen after quite a long session. The best part is that the 7900GTX is now recognized and in SLi mode set everything to Ultra High. I cranked everything further, to the absolute max and I was getting 32 FPS or so outdoors now I'm getting over 48FPS that's slightly over a 50% boost with my setup. Crossfire optimizations are added but then there is something fishy in the release notes about crossfire as well. Here are the Bug fixes
ATI Crossfire
Performance on systems using ATI Crossfire will be reduced until ATI releases an updated driver with Oblivion listed as a Crossfire Compatible game.
5. Update 1.1 Notes
Bug Fixes
Fixed an issue with falling through collision in Fort Wooden Hand.
Fixed issue with remapping controls in French, German, Italian and Spanish versions.
Fixed issue with crashes on exit.
Fixed issue with some shadows not lining up.
Going to jail while equipped with bound armor or weapons no longer crashes the game.
Fixed issue with bound weapons not dispelling properly after dismounting a horse.
Fixed issue with player shadow being delayed after fast travel.
Fixed infinite gold issue on some dead NPCs.
Fixed issue with disease resistences that made it impossible to contract vampirism under certain circumstances.
Fixed an issue where occasionally skills would not increase properly after you received an increase in a way other than skill uses like as a quest reward.
Fixed issue where spells, powers and lesser powers were being improperly resisted when the player cast them on themselves.
Fixed an issue where creatures and NPCs would not go into combat properly after being hit by a projectile.
Fixed an issue with duplicating items and unequiping the bow.
Fixed an exploit that allowed you to sell equipped items to a vendor more than once while on a horse.
Fixed an issue with items reappearing in dead bodies after saving and reloading.
Fixed crash when NPC with active light spell on them unloaded from memory.
New Ultra Low Quality graphic setting available under Launcher options with improved support for low end FX cards (5700 and lower). To use this setting, go to the Launcher, select Options and click Reset to Defaults to allow the auto detect to check your system.
Implemented SLI-mode optimizations on Nvidia cards, and Crossfire optimizations for ATI cards.
Link to the full release notes readme
http://www.theelderscrolls.com/downloads/updates_patchnotes5.htm
ATI Crossfire
5. Update 1.1 Notes
Bug Fixes
