Oblivion on a X850xt (pe)
Mayhs
Well i saw another thread similar to this but with a 7800gt so i thought why not enquire for the performance of this card :)
yeha performs great BUT what are max settings and where is that? inside or out?
I want to know too, I'm wondering how well I can run Obilvion with the rig in my sig.
you need to oc your cpu..look at those graphs
Running 1440x900 (widescreen lcd) with 2AA and bloom. Worst I've seen it dip is in the low very low 20s.
wow thats nice performance...for such an 'old' card
This game runs decent on my X800XT PE @ 1280x1024 with high details. What seems to slow me down the most is actually the indoor lighting.
What FPS do you get indoor/outdoor, and what is the rest of your system specs?
Gotta update my sig.. running it on a stock speed X850XT at everything high, all the sliders except for specular and int/ext shadows all right (the other 3 are at around 1/2-1/3), shadow filtering low, 12x10, no AA or AF, and a lot of texture/visual mods. I was just messing around with various settings and trying to get a feel for it. Outdoors in open areas it's around 60fps pretty easily, in heavy foilage it drops to 40ish. In towns it's generally in the mid-30's, groups of people can drop it below 30. Fighting (I was attacking a guard in front of 2 others at night) would drop it to the high 20's or low 30's. Sudden movements like spinning the view around seemed to hurt the FPS more than anything else, heh.
The FPS didn't really change with 10x7 + 4x or 6xAA.. at most, it seemed to drop a few FPS average. 12x10 with AA didn't matter much either for FPS, though some situations seemed to maul the card (fighting in the town took it down to the high teens).
I play oblivion on:
2.4ghz oc'd Amd Athlon 64 (single core)
2GB OCZ OC'd 240mhz ram.
2x 80gb hdd's Raid-0
Radeon x850xt stock clocks 520/540
I personally play the game on all highs (max everything) with 6xAA at 1024x768 to insure I don't go below 25 fps.
Good luck.
I have an x2 3800+ stock with a x800xl stock and get around 40-50 fps average outdoors it feels like I get much better fps indoors. Too bad there is no hack for hdr on x800.
I'm running an X850XT oced to 550/600 and a P4 3.3Ghz w/ 1GB RAM. I play oblivion at 1600x1200 no AA, 8x AF and with a whole ton of tweaks, it averages around 20+ fps in towns and outdoors. I tweaked my game and drivers a lot so I'm not sure how average this score is.
Here are some screenshots posted by someone else running on an X850XT: http://forums.guru3d.com/showthread.php?t=174693&page=9
the game looks purrty......does anyone know if ill need to have 2 gigs for the game?
It depends on how much memory you're using in the background/how crudded up your windows install has gotten(in other words, it's pretty close with high details + texture packs). I have 1GB and sometimes the game only uses like 300-400MB but sometimes I've seen it above 600.
I'm honestly not sure if my memory or video card is the bigger bottleneck at this point, but I suspect the video card more.
X2 3800+ @2.5
2x512MB Kingston HyperX CL2
ASRock Dual-939 SATA2
X800XT PE(agp)
Raptor 74GB(OS+other games)
Maxtor 2x300GB 7200RPM 16MB(no raid, oblivion is on one of these, recently defragmented)
Acer 19" LCD- game runs decent in 1280x1024 on this, I can even run 4xAA and it's fine in most areas(I think it's more shader limited than memory bandwidth limited). But I usually only use 2xAA or no AA because in the parts where it usually gets slow, it gets a lot slower with AA enabled.
It even runs pretty good on my HDTV in 1776x1000 resolution. I've played it in this manner for many many hours, the only downside is that the text isn't as clear and perhaps the video itself isn't quite as clear. But the increased detail from the resolution is obvious. It won't play that well in HDTV res in a large battle, but it's fine for me as I am a master of sneak and focus on picking people off from a distance.
Overall the game runs good for me, I think I need to tweak the indoor lighting as running into a guild hall can slow me down more than a battle in the woods. I love this game so much I'm considering a X1900XTX just for this game(for HDR +playing on HDTV or AA)- but I know that soon I will be done with this game and then I won't be able to play much of anything due to school(microbiology is a damn hard class). I'm not sure if more memory would benefit me here, but it's on the list of eventual upgrades.
bLaCktIGErs91 said:
clicky!
The last two charts.
Soooo...to answer your question.
No.
It's not that clear cut, because I've seen my free memory as low as 50MB while playing.
I have it at 1280x1024 with all high settings, no AA, but AFx8 I don't know what my FPS is (never checked) but it plays flawlessly.
any noticeable jaggies?
thnx to the first poster on this page it was nice and detailed :)
So I have a 9800pro and want to upgrade for this game.
Would you recommend the x850xtpe over the 7800GS? What would be the best AGP card for this game?
the x850xt performs the same as a 7900gt according to those graphs...but with no other graphs to back it up/no review of the 7800gs i cant say one card conclusively....sorry :p
I don't really notice them, but thats not saying they aren't there.
as i was studying about x850xtPE and happend to bump on this thread... which is very interesting! great to hear it can run oblivion decently!
i dont think 7800gs will do any justice... lo0k here and compare... x850xtPE far more superior
and i heard alot of people say 7600gt is better than x850xtPE.... i dont think so after seeing this and 7800gt is only above x850xtPE a little tiny tiny bit on serious sam2
so i think i will say x850xtPE over 7600gt/7800gt..... x850xtPE is cheaper in price! and higher performance than 7600gt! am i not right?
either x850xtPE or x1800xt,7800gtx and higher for me
I have a pentium D 820 stock with 1.25 gigs of ram and an x850xt stock and it runs it pretty well at about 75% settings at 1024by768.
Personally I wouldn't run it any higher with my rig because the game just gets... well... choppy and almost unplayable. Now, if I were to OC my cpu I bet I could increase the settings but I live in texas and it's hot as fuck so fuck that till we get into the 50's during october!
~Adam
wow i dont remember this thread :p
anyways i got oblivion and i played it at 1280x1024 with 4aa/16af perfectly and my fps nvr dipped below 30 i believe...i cant remember tho becuase its been ages...i might fire it up and see tho
