Naldo said:I found that if you turn the game difficulty up you level up faster, makes it a little more challenging though
Unlike most RPGs, leveling up in Oblivion quickly is not the best way to go about making your character better, relatively speaking.thelead said:I'm only a level 4.... i keep reading about people being lvl 15 and higher. What are some tips to get level-ups faster. And what exactly causes a level up? Is it a total of your increased skills throughout your current lvl?
Wow, do you realize you just responded to a 4 year old thread? I'm guessing the OP has moved on.....
Weight on the keyboard? There is an auto run key. I've done it before, though much easier to console: 'player.setav sneak 100'
But then cheating ruins the game.
Why am I continuing an undead thread?
I found that if I was taking too much time worrying about which skill I was using to level up it took the enjoyment out of the game. There is a mod that allows you to just play the game and your character will level up just as normal and don't have to worry about it.
Not sure what it's called but I do remember you have to put a ring on in the beginning and it has you declare everything. I found it to be much more enjoyable that way. Hopefully someone here will remember it.
EDIT: HOLY THREAD NECRO
I only wish they had implemented co-op, it'd be the greatest game of all time.
