- Apr 10, 2005
Link doesn't work anymore =(
got another site?
try this one:
http://planetelderscrolls.gamespy.com/View.php?view=OblivionMods.Detail&id=1417
edit: pay special attention to this:
"Note: The problem that a small number of people (so far ten or eleven, about 0.3% of the total number of installs thus far) reported where they are unable to load previous saves once v2.2.0 is installed after using a previous UOP (this does not affect starting a new game) has been solved. If you encounter this, please download and install this this version 2.2.2 fixed ESP file. The cause was only a few removed and moved invisible light sources in the Anvil Chapel, and occurred when Knights of the Nine was present; this ESP undoes those changes. Alternately, moving Knights.esp to before the Unofficial Patch.esp will solve the probem, but this is not recommended if you don't use the UOMP or another fix for the Knights dialog bug. If neither solution works and you need to roll back, the v2.1.2 self-installer and manual version have been reposted if required."
